Fractal Poly Close
I am trying to create a fractal poly and have it filled with a style. If I select poly or smooth poly and use the right click button I can close the polygon (and it fills it). When I try that with Fractal Poly it just ends the drawing of the polygon, does not connect it (and doesn't fill it). What is the proper method to close a Fractal Polygon so it will be filled?
You can however use a drawing tool with fractal poly and adapt it to your need (ie change sheet, layer, color...)
Thanks!
Check also the fractal depth (normaly a button showing a straight line and a fractal sort of parallel). I got something satisfying with 5 but depending on the scale you may want to change it.
Now if you want to draw a wall inside the map border (ie a box outside border an a fractal poly inside border, you must select both entities and use Mulipoly (just under fractal poly, looks like a blue sea with an island).
On the other hand, you can create a dark filled box and use a white fractal poly inside and over the box. I believe it's the usual way. The background and the inside cave are on different sheets so you can use sheet effects on the inside without affecting the map border.
Hope it helps.
http://forum.profantasy.com/comments.php?DiscussionID=516
