Symbol Set 3 has modern vector symbols for floorplans: http://www.profantasy.com/products/ss3.asp
It's for CC2 Pro, but if you buy it there will be a compatability update on your profantasy registration page so you can use it with CC3.
If you are looking for modern bitmap symbols, check out CSUAC at GM's Apprentice: http://www.gmsapprentice.com
I think doktor57 is looking for standard modern architectural symbols, like those published in the "Architectural Graphic Standards". I think the answer to that is, yes sort of. Such symbols are avalable from various companies for a rather high price. You would then need to convert them to CC type symbols since they are usualy in AutoCAD format. If I am wrong then jerdaph is right but I would add Cosmogapher as well.
If you can find some free AutoCAD furniture drawings in dxf or dwg format, you can use those in CC3. I do have some lying around, but I'm not sure about their source and any licensing issue.
I know nothing about architecture - except that George on Seinfeld used to lie to women about being an architect. Are the "Architectual Graphic Standards" something that is considered open or public domain so that anyone can make, use and distribute the symbols based on the standards?
http://www.wiley.com/WileyCDA/Section/id-301525.html
