Mapping Guide: Watabou Cities
Hi all
I have used Watabou’s city generator before, but have felt that i would like to have it in CC3+ and now i found out that it is possible!
Wow. A good way to start the new year.
But i am stucked att Importing the Map into Campaign Cartographer 3+.
It says:
Now set the current sheet to IMPORT (done that. no problem), and then use Draw > Insert file to import the DXF file we saved earlier into the CC3+ drawing (no problem here.). You will probably only see a small dot on the cursor, but don’t worry (i see the dot). This is because the scale of the DXF file is off, but we will fix that in a second.
Instead of manually re-scaling the import, just place it at location 0,0(this is where i dont get it to work. how do i place it at location 0,0?).
Any input are appreciated.
Kind regards
Grimmric
«13
