Sihjul
Maidhc O Casain
🖼️ 8 images Surveyor
This is a world map I've been working on for a little while now. I started it as a map for an RPG campaign; that campaign may never come to fruition, but I like the way the map is turning out.
I just can't decide whether or not it's finished. Sometimes when I look at it it seems complete to me, but then I look at it again and wonder about adding something. So I thought I'd post it up here for comments and advice.
This map was done mostly with the Ancient Realms annual style, with a little tweaking of colors and sheet effects.
The posted pic links to a full size Imgur post for a little more zoom-ability.
Quenten, I know I started with Ancient Realms but to be honest I'm not very good at keeping notes about how I got certain effects. I just tinker around until it seems "right," and in this case I have no idea what all I changed. A lot, I guess, since it doesn't even look like Ancient Realms anymore . I appreciate the suggestion of adding some islands! I was so focused on the bit of the world where I intended the game to take place I got a little lazy about the rest. I'll see what a sprinkling of islands a little farther out into the Lethal Deeps does for the feel.
I've been reading a bit on the forums about getting the right level of detail in a world map, so I tried to keep this one pretty minimal and focus on symbols representing large areas rather than individual objects - does the map need anything else at this level, or should I stick to continental and area maps for more detail?
The continental names are those in the largest font (Woldura, Theric, Bar-Yochai and Gwenyd).
I do need to figure out how to make the rivers show up better; they're there, but every time I try to make them stand out so that they're more visible they really stand out. To the point that they become distracting and take away from the "pretty" factor.
I also decided that this should be a map of the known world, from the perspective of the current inhabitants. The sea between the major continents is perpetually concealed by mist and fog, and the island-continent central to the world is magically concealed from all. And no one sails or otherwise travels much outside the coastal waters to the east and west - the Lethal Deeps are truly lethal.
So, all that said - this is the completed project.
So pleased you found my blog useful!
Apologies for the necro - I didn't want to start a whole new thread for what's really just a refining of an old map.
I decided to circle back around to this map and do a little more work. When I "spun it out" as a globe, I realized that while I wanted "The Lethal Deeps" to be vast, I didn't want them quite as large as I had them. I decided to make my land masses a bit larger, add a couple of island groups into the deeps, and to put an ice cap on the southern pole.
I've also fleshed out the continents and oceans with a some names.
I'd love to also post the spinning globe here - is it possible to post animated GIF files?
Larger versions in my gallery.
https://forum.profantasy.com/profile/gallery/3036/Maidhc%20O%20Casain/35
amazing work <3
Thank you, Ricko. High praise!
