Dungeons of Schley help
So I am making a tavern with the dungeons of Schley SS4 set.
I am interested in making a stage in the tavern and interested in ideas in how I might go about doing that. It is jut a simple step up dais kinda stage.
Thanks for any help.
Freewolf
    edited October 2019
    One way to do this would be to draw a rectangle using one of the floorboards/planks fills.
    Put it on it's own sheet, and apply a lighted bevel effect to it to make it feel like a 3-dimensional object and not just a flat plane, and use a short shadow on it to give the illusion that it is taller than the rest of the floor. You might also find that a thin black outer glow enhances the appearance, but shadows and glows cannot be applied simultaneously on the same sheet, so then you need to use two sheets with the same rectangle on both (make the bottom one a solid color in a weird color, otherwise the top one will have some weird holes when the bevel is applied.)
    x.PNG 1.1M
  • Thanks for this suggestion. Tweaking with some of these has helped me come up with something that will work for my map.
    I appreciate the help.
    Freewolf
