Tracing Map
I am tracing a map from a PNG file and I'm finding that the cursor is 'snapping' to points I don't want it to! I don't have the Snap turned on, but could it be affected by the background PNG pixel settings? Is there some other setting that I should adjust?
If it is snapping to pixels, and there isn't a setting to remove this (annoying) feature, would scanning the map at a higher resolution help? (I don't particularly need greater detail and the scan is reasonably large already)
A confused
Bill Howard
A confused
Bill Howard
Is Attach mode off ?
(2) Attach mode is off
The end result is that I can't produce reasonable curves as the lines keep snapping in ways I don't want them to.
Bill
The way to test would be to look at the cursor position at a couple of points on the screen, if the numbers look like those above, zoom out or in a few times and try the trace again. If this is the problem, you should rescan so that you don't need to zoom in or out so much.
Steve
Thanks for the replies, they set me on the right track!
Bill H
