How can I use Cosmographer deckplans for a saucer?
Is there any easy ways that I can make Star Trek saucer section like deckplans in Cosmographer? I've a few ideas for some ships I want to try, but are there any tools to easily help me define rooms with circular walls, etc.?
TIA - CH
    Do you have DD3? If yes, you can switch to the dungeon interface and use the Room tools to draw a circular room with your Sci-Fi fills.
    If not there's a few other ways to do it:
    - Use the basic drawing command like circle to draw the outline of your room.
    - Then either use "Change like drawing tool" (right-click Change Properties) to make the circle into a room.
    - Or use the room drawing tools and trace (e.g. using Attach mode) your outline to get the room you want.
    Hope that helps, Ralf
