Some floor and wall textures are blank
I have installed CC3 and some additional Pro Fantasy and Vintyri resources. I did the following:
CC3+
Installed CC3+ - set data folder to my chosen location
Vintryi files
Downloaded and extracted the Vintyri zip symbol folders to my data folder
Installed vccsetup.exe to to my data folder
DD3 and CD3 files
Installed DD3SetupForDD3Plus
Installed ShessarsFireplaces_CC3Plus
Installed CD3SetupForCC3Plus
Installed RandomCity_CC3Plus
Symbol sets 2 and 4
Installed SS2SetupForCC3Plus
Installed SS4SetupForCC3Plus
Installed SS4ForlornCottage
Vintyri additional resources
Installed csuac_2_setup
CC3+
Installed latest CC3PlusUpdate21 (update to version 3.90)
ran menu_recovery.bat and VPToolbarFix.bat from CC3Plus folder
When I use CC3+/DD3 and add a wall or a floor some of the textures are blank white textures -
CD3 Bitmap Digital
Dungeon SS2A
Dungeon SS2B
SS4 Dungeons of Schley
SS4 Dungeons of Schley Inks
SS4 Folorn Cottage
I have tried reinstalling SS2 and SS4 but it did not make any difference.
CC3+
Vintryi files
DD3 and CD3 files
Symbol sets 2 and 4
CC3+
CD3 Bitmap Digital
Dungeon SS2A
Dungeon SS2B
SS4 Folorn Cottage
For example, if you have a map in the standard DD3 style, and you also want to use fills from the SS4 Dungeons of Schley style, all you have to do is to use Draw --> Insert File, and then pick a map in that style to insert. Note that you don't have to actually insert the file you picked into the map, once you have picked the file and clicked Open in the Insert File dialog and you have the file at your cursor ready to place, you can just hit Esc to end the command, the fills will already have been copied tot he map at this point.
If you don't have a map in the appropriate style ready, just make a new one.
You can also import bitmap fills by using Tools --> Import Bitmap fill style.
