How to scale (blow up) an object in CC3+?
I'd like to scale up a portion of tile floor so that the tiles are twice as big.
Using the scale button, then clicking on the floor and selecting "Do It", I'm able to make the area of the floor section larger, but is there a way to *magnify* the floor section?
    The scaling of fills are controlled by the scale of the fill itself, and not the size of the entity.
    To scale fills, click the fill style indicator in the top right, switch to the bitmap files tab, select the desired fill using the dropdown, and change the values next to the 'scaled' checkbox.
    If you want to keep the old scale for other entities, you can create a copy of the selected fill in the fill dialog by hitting the new button. You can then change the scale of just your new copy, and use change properties to give your entity your new fill instead of the old one.
