[CC3+] White line in rivers
I created a map with CC3 originally, then continued editing it in CC3+. I let it lay for a while and now I'm coming back to it.
It's using the Annual Midgard Style.
When I draw rivers, there is a white line in the center of the River that doesn't go away. I don't understand where this comes from, when I start a new map using the Midgard Style and I draw a river, there is no white line. I'm using version 3.90.
Can somebody explain why these lines won't go away? (it seems it's the polyline the river is based on.
Additionnaly, I wish to open 2 maps at the same time to copy things from one to the other, but for some reason when I open a map it closes the other one. I can never have 2 maps open at the same time, even though it appears to be possible since you can minimize a map inside CC3+.
Thanks a lot for your help, please see attached pdf to see my problem.
CC3+ can only have one map open at the same time. You can have many view windows open on the same map, which is why you can manipulate the windows. To open a second map, just open a second instance of CC3+ instead.
Additionnal question:
How can I copy from a map to another, then? I read somewhere it was possible but for the life of me can't find a way to do it myself.
Also, is there a way to reset all the sheet effects to default? Because I messed up my effects and would like to restore the vanilla midgard setting.
Thanks a lot again!
In the sheets and effects dialog, there is a dropdown labeled 'Effects Presets. Choosing anything in that box (including the current value) will reload the effects based on that preset. The already selected one should be the default for the current map type, so just select that again.
