Napoleonic Battle Maps
![mike robel](https://forum.profantasy.com/uploads/userpics/320/n1CPFHI0WZSXD.jpg)
I just installed this for CC3+ and when I followed the instructions for drawing the contour lines "On paper maps the shading method uses strokes of varying weight to show slopes of different varying strength. Click the Terrain drawing tools and select the Slope 1 tool. This is the lightest slope. Use it to outline your hills and elevations as shown here." I find the Terrain Drawing Tools and it says something like I don't have any drawing tools for that type of operation. So, since my CC3 installation is still on my computer, I tried it there as well and I get the same problem.
When I use the Contour Line button, I just get a regular line.
Any ideas?
Any ideas?
Don't left-click, as that just calls up the error box you mentioned. Not sure why it does that, but hopefully this will resolve the issue for you. Good luck!
Note that the shapes in the Symbol Catalog show CA32 Slope while the fill shows CA30 Slope. No hashes. It also saves as a CC3 Map instead of a CC3Plus map.
I am guessing the CA30 vs CA32 is just a mis-labeling when the style was made (Perhaps it was intended to be issue 30? There are a couple of such mislabelings through the history of the annuals).
There is no difference between a CC3 and a CC3 plus map. CC3+ puts things in the map CC3 won't understand, but the map format itself is exactly the same. CC3+ still uses the plain "CC3" reference in many places, but this is just a labeling thing.
Thanks very much. Those actually look good. I wouldn't want to do it on a huge map.
Mike
Yes, but it is not mine. Its the product of an Army Engineer in 1876 (I think). They didn't use contour lines back then.
