Cannot use Hotkeys, write in Command Line instead
Hey everyone,
I just picked up CC3+ and started dabbling with it a bit, following a few tutorials etc. so I dont really have much experience yet.
I did however rather quickly hit a (so far) minor roadblock. I have created a landmass using the default landmass tool from the cc3+ default overworld map style and wanted to edit the landmass a bit, add some fjords and whatnot.
However I noticed that I cannot edit the landmass. when selecting the tool left of the command line appears the instruction "E- Edit", however when I press E it just writes in the command line and nothing else.
Similarly when using the landmass tool I cannot use any other hotkeys either. The arrow keys just do nothing, and all other keys just write in the command line instead.
Any way to fix this? It does not seem like a common issue since I could not find a topic about the issue anywhere.
greetings,
Panicmode
greetings,
Panicmode
Not sure exactly what to do about it, but I do recommend you start by (re)-installing the latest update, as this will ensure that all the various dll's are at their correct versions.
