Roads with sidewalks
Hey fellow cartographers, what's the best way to create a modern city road with sidewalks in city designer? I can't figure out a way to make a road, with sidewalks, that the housing alignment tool will follow and that will handle the sidewalks correctly upon intersection (ie. sidewalk stops at the intersection).
Any suggestions on how to handle this?
Just looking at the jpg, he used a brown line with width for the sidewalk.
Tana's Place Jpg and the page also contains a zip of the fcw file.
Then use the house tool to set the houses. (You can change the street width setting to make it wider)
When you have the houses and street set, on a new sheet add the Sidewalk. You can use the offset command on the road to get the sidewalk to follow the road. Add a bit of a bevel to show the curb on the road.
Unfortunately this will not be perfect and you will need to do editing, how much will really depend on the scale of your city map.
If it is a battle map scale you might as well draw it out, if it is a road map, don't bother.
Hope this helps
