Scale Font
I am working on a map, and I'm trying to use a scale from an annual issue I have. The font goes back to some kind of 'straightforward' serif font, and the Change Properties button does nothing at all. Even when I change the font, it doesn't actually change.
P.S. - I'm having some sort of glitch with the Parchment Maps scale - for some reason, I can't find a way to set the scale to the units (5 kilometers instead of 50, for example) I want.
    edited March 2019
    Text entities can only use fonts that are referenced from the current map. You'll need to hit Text Specs image and add the font required to the list. CC3+ falls back to the Arial font if the desired font don't exist.
    To change text in a symbol that isn't exposed as an attribute, you need to Explode imagethe symbol as this gives you access to the basic components.
