fractal terrain not saving/showing file extensions
When I save a FT3 map, it produces a file with no file extention, which means i can't associate the map files with the program which is a pain.
    edited March 2019
    FT3 don't append the file extension to the file name you provide in the save as (and similar) dialogs, but saves the name exactly as you provided it. It do suggest it appended to the filename as default though, so I recommend you don't remove the extension from the edit field if you are saving under a different file name than suggested (or manually just add .ftw before clicking save). If you accidentally saved a file without file extension, the easiest is to just rename it in Windows Explorer and add the .ftw extension at the end of the file name.
  • thanks, strange but it works
