Insert Map for CC3 to find the correct path
I want to insert a file so that I can add it to an existing CC3 map. How do I do this? I cannot figure out how to get my file in the correct location so that CC3 remembers the path. Loopy Sue if your out there, please help.
I placed a insertable file folder under C-Drive Profantasy CC3 and then cut and pasted my map to that folder. When I go to insert it, CC3 does not show the map. It should be a PNG file I made for the insertable map. Confused
When I get to the Profantasy CC3 and try to create a folder, it tells me I do not have Permission. The computer then offers to save the map under pictures.
Once the image is in the right place, when you are inserting it are you following the instructions in the command line? Its not just a case of clicking the Insert file option on the Draw menu and then doing nothing more. You have to click to position the thing as if you are drawing a box - click or enter two pairs of coordinates on your keyboard.
The reason I'm checking on that bit is because you haven't mentioned the giant red cross you would get if the file had been successfully inserted before you saved and closed down but the link was broken when you reopened it. If its been properly inserted but the link is broken CC3 is aware that something it can't find should be right there on your map, so it substitutes a default red cross on a white background to show that there should be something there, but that it cannot be found.
