I think they're meant to be made in tiles that can be linked together. But there is no reason why you can't just erase the borders and draw outside the initial 100x100 area to make one large map....
I'll have to dig more into the sheet and fill layout and see what I can do. But I'm busy around the house until Mid-March, so I'm not sure when I can work on this.
That's ok. I just assumed that you wanted a ring of deeper water. Now I know you want the whole thing deep with a sheer rock in the middle that's no problem.
While I moved the room numbers off to the side, I left some numbers, for locations, where the location is. I might just forget why it is there.
Anyway. Bridge, location 64. Why a bridge ? There isn't any water. At least, none is seen from the overhead view.
And there couldn't be more than a foot or two, less than a meter, clearance under the bridge ? Could there ?
Or maybe its an illusion, covering a pit. It is a long way down to level 4. Or maybe, it is just what it seems to be, a joke by the DM. :-) Or is it something creepy ?
A screen shot of second level. I may put some more maps off to the left, west, side.
I'm having problems figuring out the water around room 100. Two water sheets, water and water2, and a stone in the water, land sheet.
The floor is a non-official bitmap fill called reddish. I can change it temporarily if needed.
I'll post both the jpg and the fcw file.
When you say you are having trouble with the water, Jim, what kind of trouble do you mean?
I can't get the glow to look good.
I like the bevel on the rock in the middle.
Is the water in the middle supposed to be deeper than the rest, or shallower?
Deeper.
Do you mean in a ring of deep water, but still shallow around the island, like this?
Water2 is deeper than water. The rock is higher than both.
I tried outside and inside glow on both water sheets.
The water and water2 glows don't look right.
My apologies for not being clearer. I'm still tired from last weekend.
More like this?
Thanks. I'll download on Thursday. I keep dozing off while watching television.
Excellent ! Thank you Sue !
You're welcome, Jim :)
And here is Map 12 of 14 for level 01.
Ogres, and Orcs, and shrubbery that waves hello ! Oh my ! Ballista to the left, ballista to the right ! Duck, Dodge !
A bit of map on level 03. map 6 of 10.
A part of level 4.
The fake spiral stairs go down around 30 feet and dead end in rock.
A work in progress.
