Pen Thickness and Line Width
Hello,
I'm having an annoying issue with either pen thickness or line width. Some update ago messed with the thickness of my lines. In the attached image, I used to be able to draw lines with a thickness of 0 (boxed in green). After the update, my line defaults to a thicker line (boxed in red). I'm able to use the CHANGEPT command to set the new lines back to 0, but I want to find a way to set it that way by default.
I tried messing with Line Width, and that has it's own problems. If I set it to 0.00mm, lines show up. If I change it at all (either 0.01mm or 10.00mm, lines don't appear at all. Line style is Solid, and Fill style is Hollow.
Any idea what I'm doing wrong here?
Thanks!
Thanks!
If you have a line of any width greater than zero it automatically fills with the current fill, so if the current fill is hollow what you should get is two offset lines that describe the outside edge of a hollow line of that width.
Use the Info --> List tool to find out what those lines really are in each case, and use the change properties tool to make them right.
The line width should automatically be whatever you set it to last time you saved and closed a file (I think).
To set default pen thickness, use the PTHICK command.
Thanks Loopysue for the tip about the List tool. With it I was able to discover that the lines I drew actually were present. I set their Fill style to solid, and they showed up with the correct line width. They weren't showing up when set to Hollow because I had Outline unchecked in their Fill style some time back.
I'm finally back to my preferred settings.
