im having issues trying to use CC3+ dungeon designer.
i bought the package a while back but i never used Dungeon Designer.
Well, i went to draw up a dungeon earlier. for some reason it didnt work.
Everything loaded as it is supposed to, at least as far as i know.
however. none of my toolbars are correct. some of them wont even work. they just give me an error message.
i read somewhere there i some sort of CC3Menuconfig i ran it, but it didnt do anything.
I think (without looking) it was number 21, and the current CC3+ version is 3.90
Just a thought - since you mention having purchased the software some time ago.
That might not fix the problem, but its a point to start from.
I thought it would work like a normal map where you just select "New Drawing wizard", and selected Dungeons.
Thanks to all who helped.
By the way - when you create a new dungeon with the wizard make sure you pick one of the templates that has "DD3" in the name, and not one of those which has "CC3". You can probably summon the right files and menus into a CC3 template, but its a lot easier if you just use one of the DD3 templates.
