First attempt at a battle map :)
Hi Ladies and Gents
Please take a look at the attached battle map and let me know what i can improve on.
Its for a random city encounter in the city of Chult (sword coast)
Thanks in advance
Kieron
Thanks in advance
Kieron
The shore also looks a bit too regular. Also, if you plan to showcase the finished version here,consider including a version without the grid.
Let me know what you think :)
If you really need the grid you would be surprised how faint you can afford to make it and it still be visible and perfectly usable. Try turning the grid lines black instead of white and adding first a Glow Sheet effect set to a fairly low level so that it is only just visible - Outside and a pale blue colour, then add a Transparency sheet effect set to about 25% opacity or even lower than that.
