Fractal Terrains Pro: temperature tools acting crazy!
Help! I don't know what's with the temperature tools in FT but I found a weird little spot of extremely high temperatures right in the middle of a tundra segment, so I tried to paint it out with the paint lower/temperature tool.
I found the temperature tools to be extremely unpredictable. Sometimes they work, sometimes they do the OPPOSITE of what I have them set on, and sometimes they do nothing at all. I've spent half an hour trying to fix a spot that was initially only a tiny area and has now spread because of the behavior of the tool. What's with this?
  • 26 days later
  • I found this sometimes happens too. I was trying to raise the temperature of a region by a couple of degrees. Instead, one sweep of the tool and the temperature dropped over 200 degrees!.
    The work around I cam up with is use the select tool on the area you want to adjust, (which type of select tool depends on what you find easiest) then use the global adjust which will only effect the selected area.
