Edge Striping Width
Hello!
I was wondering if there was a way to get the Edge Striping tool to have only one strand based on the Map Units setting, but that one strand is FARTHER AWAY from the coastline than the default which is -- near one millimeter.
    edited January 2019
    Edge Striping uses a raster image to generate the effects, so just replace it with the image with your desired striping setup. The default stripes are stored in @Filters\Images
    An alternate way to generate edge striping is by using the CONTOURSM command. See this article for some information (That example generates contours from a raster image, but you can also do so from CC3+ entites.) Using the command, you can specify distance, and thus generate an edge stripe in whatever distance you need.
