CC3+ Black Screen & "Error Loading File"
Please help me guys. I purchased CC3+ two months ago, and I have been using it forever, working on two specific maps. I had done so much work on them until - BAM. A few days ago, every time I opened one of my map files, I got the error attached. I think the file is corrupt, and I REALLY hope there is a way of fixing this. I tried using Profantasy.com tech support, but I'm in America, and there time zone is messed up with mine, and they reply when I'm gone. Please help. I tried updating CC3+, and THAT didn't even work.
Unfortunately you may have to be patient and wait for tech support on this. I'm a bit confused as to why the time zone difference is a problem. Its not usually done by phone but by email.
I say 'unfortunately', but in truth you are lucky - we all are. Tech support at Profantasy is five star
If a new file is working fine, what was the last thing you remember doing to the corrupted files?
Did you perhaps decide to delete all the Layers and Sheets, or did that just happen all by itself?
Unfortunately, the file has nothing in it, so yes - it looks like a tech support job. Sorry!
If you have, save it immediately as a new filename somewhere safe in your Documents folder, as things get a bit awkward if you continue to draw in the autosave file when it next tries to autosave.
Just a note about the autosave - if the file you have open when the autosave happens is corrupt, then the ok autosave file will be overwritten by the corrupt one that is currently open. That is why I suggested that if the autosave file was ok you should save it immediately under a new filename to preserve it if the main file can't be repaired. CC3 only has one autosave file, which is overwritten every time there is an autosave no matter what file you have open.
I am assuming that when you removed the battery you were already on mains power, and that your laptop is one which can operate without a battery as long as it is plugged in to the mains. Its not a manoeuvre I would really like to risk with unsaved files or even open apps on my screen. I am just a user like you, but my instincts are telling me that the removal of the battery might have something to do with this.
I do hope that Profantasy are able to recover your map for you.
There has been a big jump in Internet use due to this being a big holiday. Have you tried downloading at different times of the day ?
And always install as admin by right cicking on the file after downloading and click then on INstall as Administrator.
I'm not sure how you ended up with files that have the same sort of very specific corruption. I certainly hope that it doesn't keep happening.
I'm happy that I can help. Keep on mapping!
