Copying Symbols Creates a Load Time Per Click
FarsightX3
Surveyor
Like the title says. Essentially, for some reason when I use the copy icon to the left of the symbol catalogs, when I copy a symbol, there is about a 5-10 second load time per click when I place a symbol. Never had that happen before. Any idea why that's doing that? Thanks!
Are you talking about symbols that have been imported through the Symbol Manager, or just pasted into the map directly from the folder?
I don't know either.
How many symbols are on your map altogether? I have a very limited laptop, so by the time I'm half way through a reasonable sized city it all gets a bit slow, including the pasting/copying of symbols. Other things that can make a map rather slow are; an excessive number of nodes in large and complex shapes such as coastlines, and having imported thousands of different fills and symbols from several different styles to mix together.
Below is my Count All
Try moving all the symbols in different regions to different layers (you can create new layers for this purpose), and hiding the regions you don't actually need to see while you work on the bit you need to work on.
