Fractal Terrains won't return to normal map
I'm not sure what to do, but the program has been unable to return to normal since I hit the Gaia mode. I've closed the program and rebooted comp and it just returns to this. Considering a reinstall. I also told it to not remember to reboot with the same last settings, but it appears this way whenever I hit normal map mode. It feels stuck in gaia mode and it won't allow a normal mode. Gaia mode still works and so do all the climate, etc.
An actual Normal map is most useful when you export it together with the Altitude image and combine the two images in a 3D modelling environment such as Blender, where the normal map deforms the surface of the planet to take the actual shape of the land - true relief mapping in 3D. That's all it is.
You don't need to do a reinstall. Just pick the Show Altitude option
Now I can go away and make lots of lovely realistic looking 3D planets in Blender, using the normal map
It does cause confusion at times, but this is not Profantasy being awkward. Its the accepted name of these very special red blue and green images in the 3D modelling industry.
Selecting color scheme tab, and double click on one, then click on Apply, until you get what you want.
I use cc2 gree to grey
