Links to paper/parchment textures and backgrounds
Hi all :)
Following a recent development in my texture collection I have decided to make two small collections available from my OneDrive folders.
Seamless Paper
The first collection is a set of 10 plain parchment fills suitable for those really large maps where you just want to have a paper background that will stay very much in the background and not overpower the finer details of your map. Some of them are very similar to the fills included in the 2017 Annual bonus issue (in fact two of them are modified versions). The rest are new textures, and all are very large. These 3000 pixel fills can slow your map down a tad, so there is nothing wrong with picking just one or two if you want them and leaving the rest.
https://1drv.ms/f/s!AgJAv-rukPfHpWoeKSXP1V4naI4l
Background Images
The second collection is slightly different. The images in the 'Background Images' folder are as the name suggests intended to be used as background images using the Import File menu. These images are much larger than the fills, being 6000 pixels square. This would make them completely massive as png files, and since they are backgrounds rather than fills they have been converted to jpg files to keep the size under control. The images are square, but if you use the screen or frame of your map to pick the bit you like for the background of your map, the rest can be trimmed out of the shot. I would not recommend distorting any of these images to fit the map.
https://1drv.ms/f/s!AgJAv-rukPfHpWvcs0vTsUszDACZ
IMPORTANT NOTE: These collections don't contain very many textures and images, but all together they are a 150MB download.
