Adding Sea Contour to a map imported from FT
I have another noobie CC3+ question. I recently imported a FT map, edited the land found in the Contours (Land) sheet. I attempted to add the coast outline from the Sea menu, like in the tutorial, but it just pasts that on top of the land (unlike the tutorial). Related question - I edited the Land in the Contours (Land) sheet, but I see that there is still an outline in the Land sheet. Do I need that outline? Can it be removed/regenerated? The coastline of the entity in the Contours (Land) sheet no longer match the outline entity in the Land sheet.
Thanks in advance!!
Thanks in advance!!
For the outline, you can delete it, and to add another, you can use Outline in Black
