Square Fill not matching grid scale
On page 248 of the Tome, it describes creating a grid that appears just on the floor - very cool.
However, I'm having trouble in that the grid that's created is close-to but not exactly on the same lines as the official hex/square grid.
How can I adjust it to match?
Just like any other entity, you can move the grid, you just have to use the On/End/etc modifiers to make sure you get them exact.
I don't really recommend using bot a normal grid and this fill grid in the same drawing though, that will quickly cause issues like this.
(You could also edit the symbol the grid is based on to get things to sync up, you would need to measure the offset you need by measuring the distance from the lower left corner of your room to the grid corner, and then place the top horizontal line of the symbol that amount from the bottom of the symbol)
They are close, but not the same. They are significantly different in Volume and Weight.
1 liquid US gallon = .833 Imperial gallon
1 dry US gallon = .968 Imperial gallon
(Yea, wet vs dry gallons, ugh!)
1 US ton = 2000 lbm where 1 British ton = 2260 lbm
And no, we don't like it either, but it's what people know (even though we "went metric" in 1976, people and businesses just refused). And people are stubborn.
