CA3 alignment issues
I've started using CA3 recently and am noticing a bunch of alignment issues with things like arms, or where body parts are drawn on top of clothing and such.
Attached is an example using one of the default templates. I selected the Human Male, and placed the HMT torso W and the HMAL 1 Arm W. As you can see here, there is a gap between the torso and arm.
Same setup as the above post, I just added the HMT Shirt 1. The reason is pretty obvious, the arm is on the "Arm Left" sheet, and the shirt is on the "Torso Shirt" sheet, but the ordering of the sheets has the Arm Left over the Torso Shirt.
I've been following your posts on CA3+ and your advice has really helped. However, the annoyances keep mounting heh. I, too, have noticed what mattekure is saying and am just wondering when we can expect some serious updates to CA3+. It's an awesome program but needs some serious luv :P
thanks
Cal
