hex grid
HelenAA
🖼️ 19 images Mapmaker
Yesterday I did something that caused the Hex grid to appear and I couldn't find anywhere to tell me how to turn it off. I looked in Help and there was something about turning it ON but nothing about turning it off.
I looked in the User Manual this morning and did a Find search and discovered that there was only TWO occurrences of the string of letters "h e x" (but without the spaces). They're both on p.79 if anyone wants to know.
Why isn't there anything about getting out of this mode? When I made the map to start with I didn't check/tick anything about the hex options, by the way.
Helen - who is starting from scratch
Other alternative ways to just select the grid:
- Hide everything but the GRID sheet.
- Click the Erase
button, and then right-click on the map and choose Layer from the popup menu.
I hope that helps.Right-click again to open the Select Layer dialog.
Select the HEX/SQUARE GRID layer and then click OK (you don't have to check any boxes, just click the layer so it is highlighted in the list). All entities on the chosen layer will be selected.
Then right-click and Do It.
Cheers,
~Dogtag
