Symbol Catalog buttons won't work
Hi,
After not using CC3/DD3 for a few years I've bought the upgrade to + and reinstalled on Windows 10
For some reason though the symbol catalog buttons don't work. When I click on them rather than changing the list of symbols a dialog pops up called "Available Symbol Catalogs"
But none of the options in the catalog seem to help. I can open the catalogs by manually browsing to them on my disk but I'd like the buttons to work as intended. Am I doing something dumb here?
Thanks
    This happens if the master filter is not set correctly. It should normally be loaded with the map, but if it isn't, you should be able to set it by simply hitting the DD3 add-on button once.
    As an alternative, you can also load the master filter by right clicking the symbol style toggle button. If the correct list is already loaded, just activate the DD3 Color option, if not, hit load and pick the DD3 list first.
  • Thanks very much. Right clicking the symbol style toggle and loading the right list fixed it :)
