CC3+ Toolbar Missing (new user)
Hi! I'm a new user of CC3+ and I also have City Designer and SS3v3 installed. The toolbar for CC3+ (the one with landmass, rivers, etc) isn't appearing. I tried running CC3MenuConfig but it didn't change anything. I'm including a screenshot ofthe left side of my screen so you can hopefully see what I mean. Any ideas?
Thanks!
Thanks!
1) Type
MENUDM @fcw32.mnuon the command line, and then hit enter2) Check if you have the file named fcw32.mnu in your CC3+ data directory
3) If you have the file, try opening it in a text editor, like notepad. It should look very similar of for example ss3.mnu found in the same directory
Otherwise, if you just contact support and explain the issue, they'll probably just send you a new copy of this file.
All ideas are welcome, and none are judged like that - least ways, not by me they aren't
Just judged by myself.
And that is alright.
EDIT: I had a brain malfunction there - running the update will not fix a broken menu, you need to run a repair install of the original setup file to do that.
Please contact tech support from your registration page (i.e me) if you are missing something or something is broken. We can always provide the safe, clean, unaltered version from the setup files.
