Fractal Terrains as a KML
A while ago I made my world map using FT3, I now have a beautiful TIF file that I commissioned. I would like to convert this into a KML file to display on Google Earth, I am having trouble finding a way to convert this and/or import it to FT3.
Is there a way to do this?
(Note that a kml file doesn't contain any graphics, a kmz file is basically just a zipped .kml file whith images and other resources also in the file, ready for use with Google Earth)
Once your image meets the FT3 import requirements, use Image Overlays>>Show Overlay Window in FT3 to show the Image Overlays window, then click Add to bring up the Edit Image Overlay dialog and then click Import Color Image to load your image file to your drawing. Note that you don't need your original FT3 world for this step because the image will presumably cover the whole globe.
After you see your imported image overlay on the map, use File -> Export World -> KMZ File to save that image as a KML file. The KML export in FT3 is a single-image whole-world export, so it won't have a huge amount of detail. That sort of thing might be acceptable for your world, though.
