Odd printing problem...
I am printing to Adobe PDF. here are my settings:
Under Adobe PDF Properties
High Quality Print
ANSI C
Everything else is left as default
In the Print Drawing window:
Active Window is selected
All visible sheets is selected
Fit to page
Tiling - Horz 1, Vertical 1, Overlap % 0
Landscape
I click Preview and it looks like my map. I click OK to print my map and all that shows up is the outline of my landmass, the roads, the lakes and rivers. Everything else is missing. What gives?
JSM
High Quality Print
ANSI C
Fit to page
Landscape
JSM
When you say 'all visible sheets' are selected, you do mean 'all visible sheets as one page' right? (as opposed to 'all visible sheets as separate pages')
Do the same thing happen if you use another pdf printer (If you have Windows 10, I believe it comes with the microsoft pdf printer)
JSM
JSM
JSM
JSM
I looked a bit at the adobe settings, and discovered that the high quality print setting you are using actually defaults to 2400 pixels per inch. I think this forces CC3+ to render a larger image than it is capable of. When printing, CC3+ must still render the output. I recommend you try at standard quality print, which is still 600 dpi, which is still high enough that you would struggle to differentiate it from the high quality print in most scenarios. (Most printers use 600 dpi anyway [although you can easily get better ones though])
JSM
Be careful when checking what resolution is being offered though - ppi = pixels per inch and dpi = dots per inch are NOT the same things.
