SS4/DD3 question
I recently picked up SS4 and was going to walk through the PDF that came with it to learn the ins/outs and one thing I noticed at the very beginning is this.
Click the Add
Room button, set the floor
background to the Wood
Floor Pine h fill and the wall
fill style to Natural Stone 5.
Set the Wall width to 0.5.
Then...
Rooms without DD3
If you don’t have DD3
installed, clicking the Room
button will instead offer you
a selection of drawing tools.
Choose Room, Wood Floor,
Stone Walls for this example.
A room drawing tool works
similarly to the Room command from DD3, it is just
a bit more complicated to
change the floor and wall
fill styles.
So I noticed right off that when I clicked ADD room it didn't react like the first instruction suggested but like the 2nd. I have Both SS4 and DD3 installed. At the time I had selected SS4. Here is what I saw.
ss4 selected
https://i.imgur.com/SdeblMY.png
dd3
https://i.imgur.com/ZvPgVwe.png
Is that how it's suppose to work? I got the impression from the docs that it should work like the first method described if I had dd3 installed while using ss4... but it doesn't appear to be?
I'm using current rev of cc3+
Click the Add
Then...
Rooms without DD3
fill styles.
ss4 selected
dd3
A little annoying, but once you get used to it, not a big deal.
I also recommend editing the OnOpenMacro map note in the map to run MENUDM @dungeon.mnu instead of MENUDM @ss4.mnu as this will simply load the correct toolbar at map start (while keeping the correct style, so you don't need to manually set master filter either)
