Trying to use distance lines in sector map.
I'm trying to map a sector of galaxy using the sector map. I can measure the distance, but I can't get the software to draw and label the distance between two points. In my universe, direct routes between two systems rarely occur in a straight line. Therefore, there have to be waypoints where the pilot would need to recalculate the next "hop". But when I select the Draw Distance Line tool, it asks me to select the height symbol. I'm using a 2D map, so no matter what I select, a line is never drawn. Is there a setting I'm missing?
I used colors for each layer with is a set distance apart. That doesn't give me the diagonal distances between layers, but its the closest I can come to a 3D sector map.
Here is what the map looks like, shrunk to 70% of the original 1200 pixel wide png.
Note that for some reason the image maps on that site give me wrong links, I'm not sure what happened as they did work. The menus at the top of my site are a much better way to navigate.
