Making Grids Appear Under Entities
Is there a way to make grids not overlay entities? In one map I am working on I have tried to select the grid and send it to the back and this hasn't worked. I have also tried moving it up and down the sheets menu, and this hasn't worked either. I also keep accidently selecting the grid and moving it when I select other objects. I have taken to hiding the grid when I've tried to select but would love a way to just have the grid sit there and not change while working on other elements of the map.
Thanks!
Thanks!
The grid can also be frozen by freezing the LAYER it is located on (Done from the layers dialog). The grid is usually on the HEX/SQUARE GRID layer.
