Contour Falling to Back of Sheets
I returned to an old CC3 map I had done years ago and wanted to save a PNG copy out to use on a website. When I go to apply effects to the text in order to get a glow effect all of my contours fall to the back of the sheets and I can't figure out how to restore them. Any suggestions?
thanks!
thanks!
Alternatively, change the Effect Units. For overland maps, the Effect Units ought to be Percent of Drawing Extents Width, though Map Units work okay, they just don't adjust much with zoom. Another problem can be if the units are set to one Effect Unit but you thought they were another when you adjusted the effect values.
I hope that helps.
Cheers,
~Dogtag
Back in CC3, all effects used map units for effects sizing, but in CC3+, a choice was added to most effects to offer relative sizes too. What happened here is that the edge effect defaulted to percent of view width since no explicit setting was set. So the correct fix for your map should be to edit the effects, and set all the Effect Units to Map Units, since that is what CC3 would have used them as, and what you tuned them for.
