Feedback request! (UPDATE 6) Waterfalls and Statues!!
ahawk1972
Traveler
I am working on a large map and got an area put together now the lower areas and the areas to the right are not complete. I am been playing with shadowing and adding some of my own home PNG files. Give me some feedback please!!
Thanks!
Thanks!
I really like the way you've done the crevasses. That looks really good.
The problem I have is that the ice, sea and ocean textures are all quite heavily pixelated, which means you have the scale too large.
The ice isn't too bad - just on the borderline of being almost acceptable, but the snow and the ocean aren't very pretty at all. See how blurry they look against the sharpness of the land?
Try scaling them down in small steps until they don't look all blocky and pixelated like that, and it will look perfect
Thanks!
I will say when I look at the overall map (zooming out some) that it's a very catching image, nicely done.
Thanks!
Direct Link to zoom https://i.imgur.com/uHMESt9.jpg
Not happy!
Shorter version (in case it happens all over again)
Love the map - very pretty. Your water falls are very good - better than mine by far.
Don't like the dividing water channels and multiple outflows from single lakes. That wouldn't happen unless the issue was forced by man. Hope you are going to make them canals and not just leave them as 'natural channels'.
Fills look a lot better
I really like the way you used the crevasses, but at the same time, I'm a little bit unsettled by them: They build up a ladder with lots of huge steps, but at the same time, it looks like the step at the top left is at the same height as the step at the bottom left, since both touch the same sea. I'm not sure how this could be improved... But right now it looks a little bit like some M.C. Escher drawing to me... But it's still pretty cool
what are your thoughts?
What I did was took the river to the edge of the cliff. Placed the waterfall below and then wrapped a lake around it. Here are the ones I liked the best.
Direct Links
https://i.imgur.com/lYqlSNu.png
https://i.imgur.com/wi1Froj.png
Thanks!
This article might help:
https://en.wikipedia.org/wiki/Salt_lake
Thanks!
Thanks!
Direct Link: https://i.imgur.com/Jiode0g.jpg
Direct Link: https://i.imgur.com/YEE5xuP.png
Thanks!
You might need to invoke a similar heat mechanic to keep the rivers flowing and stop the lakes and waterfalls from freezing, and possibly also the seawater in the fjords and other coastal narrows especially, unless you're using some magical option with the water in places.
I noticed you've used both the ice and snow terrain fills. That suggests one is meant as ice-cap/glaciers, the other as possibly only seasonal snow cover (unless you were just aiming for variety across the ice-cap area more generally - I've done this, certainly). That might suggest there could be some sea-ice and/or glaciers/pack ice extending out over the seas as well. At present, it looks as if all the snowy/icy coasts are snow/ice free, which isn't really what happens on Earth - some may be, but not usually all. That can be seasonal, however.
Direct Link: https://i.imgur.com/NfJ5tMN.jpg
Thanks
Thanks!!
Thanks!
Direct Link: https://i.imgur.com/j5DUGru.jpg
