Oopsie! Symbol Catalog Turns to Red Xs...
ScottA
Surveyor
I understand the basic reasons for the red Xs you sometimes encounter. My issue is that I decided to change the file name of one of the symbol catalogs I recently created and now all I read are the dreaded red Xs when I try to load it up to edit the catalog. I even tried changing the name back to its original but still get the red Xs. How do I repair this and what is the proper way to change the name of a symbol catalog? I did it in the Windows file menu, but apparently, that is a no-no.
You get the red X's when the path to the symbol bitmaps no longer matches the path stored in the catalog. Did you make the catalog via importing PNGs? Did you move the catalog or the PNGs at all? Keep in mind that when you create the catalog you can choose to store the paths absolutely (that is, with a full path) or relatively (to CC3+ or to the current drawing). You should use a path relative to CC3+ but, if you used an absolute path and then moved things, the paths will break — even if you kept everything the same relatively. You can also get red X's if the symbols use bitmap fills that are not saved in/related to the current map or template. Again this is due to CC3+ being unable to reconcile paths.
Load the catalog ion CC3+ and from the Symbol Manager "Edit" one of the symbols showing a red X. Use LIST on the red X to show the path CC3+ is looking for. Does that match you current location of the PNG files?
I think I've probably avoided most of the pitfalls by deciding on my naming conventions before I even started with making my own catalogues, and never changing it at all.
Do remember that symbol names and file names are not connected, so in most cases, there are normally no reason to change the file names, people won't normally see those anyway.
