B&W Annual no 4 Cities Water Features
Hi,
I'm new to the mapping. One thing I can't work out at this point is that if I add a stream in the cities map (using B&W annual 4), how can I add some texture to it, such as ripple lines or waves?
Thanks,
Thanks,
You could try adding a new SHEET to the map and drawing the flow lines onto the river with white? Adding a small Blur sheet effect to the new sheet might be helpful?
If you are new to CC3+ and that doesn't make any sense, just shout and I'll describe it in more detail for you
