World Map Completed (2)!!
See last post for new map link.
The World of Tarumar Map is finished! Because of the size of the jpg, here's a link to view it. LINK
Next is making each continent into its own map file.
And that compass rose looks a little bit too much in the middle of the map. You have plenty of wide open corners to put it in.
Monsen, I will be working on the effects in the next day or so.
The map I was working on, I measured the distance of that and wrote it down. Made sure all layers were showing and unfroze all layers.
Next I did Edit > Reshape > Scale, selected All then typed in 24000/the distance number I had written down, then clicked Do It.
It's a bit easier than copy+paste because everything is on the same sheet/layer and you dont miss copying things that you may only nitice when it's too late.
Then from continent maps, I can make regional maps. That's a little more work if the area happens be along the coast.
I open my map, zoom in on an area I want to develop in detail, right-click on the "copy" tool, select "copy to clipboard" and being selecting stuff. Once I have everything selected, I right-click and select "Do it."
Then I open a new map and choose paste. I either get nothing, or if there was some text on the windows clipboard, a URl or something, I get that.
If anyone can point out what I am doing wrong, that would be great, and I appreciate the help.
If you look at your command line at the bottom, after selecting objects, and "Do It", it will tell you to select the origin of the copy. In most cases, this will either be 0,0, the center of your selection, or the corner of your selection. You can type in coordinates by hand, or just left-click anywhere on the map to use that point. Only then is the copy procedure complete and ready to be pasted.
Many thanks!
Hmmm, doing effects is really giving me a headache. If I do effects on the landmasses, I lose the effects done on the sea contours. What am I doing wrong?
