bug after inserting a file
I tried to insert a cave map into a new drawing as described in Annual 07 - Caves. It inserted fine, but when I tried to list the entities, instead of it prompting me to select an entity the entire map is automatically chosen and the list window pops up. There's now a new, higher level above the entities that says:
"fslod entity: color 0 (black) layer 0 (MERGE)
line style 0 (solid) fill style 0 (hollow)
line width 0" tag # 0 pen 0.00 mm 2nd color 0"
It doesn't matter what tool I use - I've selected change properties, erase, etc., they all auto select the entire map.
I've loaded map files that weren't used in the file insert in any way, and the same behavior.
I tried re-running the last update (13a) but that didn't change anything.
I'm not sure where I went wrong or how to fix it.
Edit - hmmm...tried to insert an imgur screenshot but that didn't work. Here's a link to the screenshot
https://imgur.com/cI83e1M
    Your selection method have changed (Possibly because of a macro aborted halfway through). You can get back your regular selection method by going to Tools -> Options -> Select Method -> Dialog or Popup, or by typing SELBYD on the command line.
  • Hey, thanks!
    Prior to doing the insert I did try out the RALONG macro in annual 33, so I might have goofed something up there and just not noticed it until I inserted the file afterward.
    Appreciate the quick info, and glad it was a simple fix.
