Exporting maps as cropped images with fixed width and height
As the title implies, I'd like to know if it's possible to export a map in four sections with each section being of a uniform width and height, all the while being cropped to the aspect ration. I am aware that without the aspect ration the sections are uniform but have a white band above and below the final output as an image.
Select one of those, give a filename.
Then on your map, draw a square of rectangle using the tool that comes up. Upper left and lower right corners. The program will export the graphic file.
Give each of the 4 filenames a different name.
All done.
You'll find more about using coordinates in this topic.
Also, if you have this year's annual, there is a script in issue 129 that does all of that automatically, you just need to comment out the line at the end that deletes the individual tiles after stitching them together. (The script is intended to enable very large exports by exporting the map in parts, so it assumes you only want the final result, not the individual tiles by default.)
the four section dimensions after export are as follows:
1: 6000 x 3479
2: 6000 x 3693
3: 6000 x 3827
4: 6000 x 4062
also, the reason why this bothers me is when I put the four sections together in Photoshop there is a visible seam between the top and bottom section and some lines are misaligned.
Crop image to aspect ratio should be enabled.
Once all options are correctly set, and assuming you didn't make any calculation errors when calculating the coordinates to use, the resulting tiles should be identical. As for the calculation, make especially sure that the width is calculated correctly. I see that width is the limiting factor here, so if one section is just a bit wider than the other, that will force CC3+ to scale down the image a bit to fit within the limit, which results in a shorter height.
Based on the coordinates in your above post, your export coordinates for a 2by2 export should be (-400,-400) => (13000,8000), (-400,8000) => (13000,16400), (13000,-400) => (26400,8000) and (13000,8000) => (26400,16400), does this match what you are using?
I know I am asking to verify a lot of details here, but when everything is set correctly, two areas of the same size in CC3+ should always result in the exact same size in the export too, but it is very important to use exact values when you have tiles you wish stitch together.
I just tried to export using the coordinates you provided for the first tile (which I have also used before, so my calculations were correct yay), and I got a final image with 6000 x 3762.
Try exporting one of the other tiles from my list, it should result in the same size as the first (Due to rounding, exports may sometimes be one pixel off, but not the sizes you reported above with hundreds in difference.)
It's easy to make tiny mistakes when doing this, especially since CC3+ doesn't have an built-in mechanism for producing tiles, so you kind of need to get it exactly correct for every tile. (and even if your input is correct, you may get burned by the 'restrict to map border' feature - very helpful for whole map exports, but can be a bane when doing tiles)
That's why I wrote the tile exporting script (the one found in the annual), to save myself from much work and easy mistakes. Before I wrote that, I used an Excel spreadsheet to generate the command line for each tile me, but that had to be calculated separately for each map and number of tiles.
I’m hoping to design some dungeon maps that will fit on standard letter size paper with 1/4 inch borders on all sides. I want each grid square on my dungeon map to be the same size as the AD&D TSR adventure modules used (1/4 inch perhaps) that represented 10 feet. Are there certain map height and width settings that I should use when first creating my dungeon map and export settings (pixels per inch or size dimensions) that I should use? Restated, what’s the easiest way for me to design a dungeon map in DD3+ as if I were drawing it by hand on a single sheet of actual grapgh paper?
A letter size paper is 8.5 by 11 inches (If my memory serves me correctly, I am a bit shaky on those exotic paper sizes, so If I misremember this, simply amend my calculation to get the right numbers). Since you wanted to use 1/4 inch margins, that should leave us with 8 by 10.5 inches for the printout. You wanted 10 feet on the map to be 1/4 inch on paper, so that leaves us with a map size of (8 * 10 * 4) by (10.5 * 10 *4) feet = 320 by 420 feet for the map size.
so the resulting map would be
(8*10*4) by (10.5*10*4) feet = 320 by 420 feet
