Maps from Fractal Terrains to CC3
So I am new to use Fractal Terrains and I created a world I like. I have been playing around with exporting and I found a way to zoom in on what I want and exporting the view. I exported with coastlines only so that I am free to create things the way I want. Once I open the new map there is no map border and I cant see the scale things are set at. How do I add a map border and see the current scale.
Note: I had to run FT3 as an admin to change the options. I was making all sorts of changes but nothing was actually working as the program didn't have permission to save the changes.
Sub-Note: There's quite a few of us playing with FT3 within the FB Group. Might find some help there also: https://www.facebook.com/groups/1830466227284189/
I will take a look at the FB group, thanks!
Also daplunk, are you on every RPG forum out there? LOL
Yes haha good to see you again
For map border and all that stuff, I recommend just creating a new map in CC3+ in the style you want, and then copy over the exported coastlines from the FT3 export to that map. The FT3 export is rather basic, and doesn't look like any of the beautiful styles you can use in CC3+. You can then use Change Like Draw Tool on the imported coastline to turn it into the style of the map template you used.
