Campaign Cartographer 3 - Cannot use keyboard shortcuts
So, I've been playing around with the tool and trying to learn from tutorials, but I've run into an issue I can't seem to figure out how to fix.
When using the Land Mass tool, I press "e" to Edit, but instead of changing anything it instead types in the status bar at the bottom of the screen. It tries to input anything I type into the bar as a command, and none of the keyboard shortcuts work because of it.
Does anyone know what's going on?
    Do this happen with all tools/all maps? For example, if you restart CC3 and start a new map in the CC3 default overland style and use the default landmass tool, does it still happen?
    If you look at the command line with the tool active, does it display 'e - edit' as an option in the prompt text?
    Also make sure you have the latest update to CC3 installed, available from your registration page. There have been updates since the latest installer was built.
