Edit Properties
Just getting started with CC3+ and DD3. I have noticed that if I edit an objects properties, it will change as desired, but if I edit it again, the dialogue doesn't show the properties in their new states, just defaults back to generic "black color", "solid line", "solid fill color", etc.
Why do the actual object properties not show up when using either the Edit Properties or Change Properties?
This also makes it very easy to set the properties of one object like another, just extract the properties of the template entity, use change properties on the target one, and everything is already filled in properly.
If you want to see the properties of one or more entities, you can use the LIST command (Info>List from the menu bar). It's so useful, it's the first command Monsen spotlights in his wonderful Command of the Week series of posts. You can find his detailed description of LIST here.
And, welcome to CC3 and the ProFantasy forum, Conandy!
Cheers,
~Dogtag
