Map to Poster
ld like submit my map to one of those online poster printing sites. I need a hi-res copy of my map for the process. Can someone walk me through the steps to convert a CC3 image to an expandable and printable image? When I try it I get an image that cant be enlarged or lose all detail.
Can you try exporting it without antialiasing on, that will skip the finalizing step that is most likely to fail.
(The reason for failing is actually memory usage. Sometimes, the output image is so complex that it ends up with a huge file size, which the converter fails to handle).
