Paste onto a added sheet (noob)
I searched the forums first but couldn't find any help with this. Not sure if I was just asking the wrong questions in search...
Preamble:
From FT3, Ive created and exported a continent outline into CC3+ but it doesnt have nodes so I need to create a new outline in order to makes tweaks to it. So I copied the outline to the clipboard, added a new sheet to paste onto (made sure the new sheet is selected), and pasted. No problem but...
No matter if the new sheet is active it pastes the outline onto the existing Contours (outline) sheet where the untweakable export is.
How can I paste onto the new sheet?
Thanks in advance
Preamble:
Thanks in advance
However, if you are inside the same drawing, don't use copy/paste, that isn't the best tool for the job. If you just need to copy it to another sheet, use the Copy to Sheet command instead (found by right clicking the copy in drawing button)
I am a bit confused as to what you are doing though. What do you mean it doesn't have nodes? And what do you want to accomplish by copying it? A copy will normally behave exactly as the original.
Note that the inability to edit an outline exported from FT is because it is a multipoly (You can choose in the FT export options if it should multipoly each export level or not). Multipolies cannot be edited, they need to be exploded first.
Personally, I prefer exporting just the coastline though, as I usually use hills/mountain symbols to represent height in CC3+ rather than contour line, but if you want them, they are fully editable as well.
Also, I made a archipelago area in FT which looks ok on the continental scale but when zoomed in to what would be a regional scale, its just a bunch of ugly shapes, so eventually I`ll want to pull from the map to make a closer-in regional map (not looking at ToK at the moment and forget the term it used) and need the ability to tweak them when the time comes.
Anyway, I tried exploding an entity but still getting a "this is not a Polyline" message. So, as painful as it`ll be, with my current level of understanding I think I have to go with ScottA`s method.
