Select Catalog Setting no longer shows symbols in DD3
Tonight when I attempted to open a symbol menu for DD3 by clicking on one of the symbol buttons (such as the door, steps, sword, etc.), I'm seeing a blank menu in the Select Catalog Setting window - no symbols are shown.
Any idea what's going wrong?
    The wrong master filter is loaded. This is normally loaded with the map (unless you delete the OnOpenMacro map note), but it can be set to the wrong value by switching back and forth between add-ons.
    The easiest way to fix it is normally to just close and reopen CC3+ (and reloading the map, if needed). If that doesn't help, right click symbol style toggle, select 'Master Filter Settings'. In the dialog that appears, hit Load, and load the DD3 Setting, and then make sure 'DD3 Color' is the selected item in the list. Hit ok, and the button should now load the symbol catalogs again.
  • Yep that did it, thanks again Monsen!
